July 16, 2013, 06:48 |
CFX Oscillating Cylinder FSI Problem
Vipul
Rep Power: 12 |
Hello everyone,
I am trying to do a FSI simulation in CFX using CEL expressions, the problem is of a cylinder mounted on a spring damper system. The expressions used are similar to the ones used in the tutorial with the addition of a damping coefficient term. But unfortunately the amplitude of oscillation predicted by CFX is much higher than the reference values. My CEL expressions are as follows, m = 1.1e-4 [Kg] K = 12.012 [N m^-1] C = 5e-5 [Kg s^-1] FFlow = force_y@INTERFACE (INTERFACE is the interface between the cylinder and fluid) MeshVel = areaAve(Mesh Velocity Y)@INTERFACE YOld = areaAve(Total Mesh Displacement Y)@INTERFACE tstep = 5e-4 [s] Numer = (m*YOld)/tstep^2) + (m*MeshVel/tstep) + (C*YOld/tstep) + FFlow Denom = (m/tstep^2) + (C/tstep) + K YNew = Numer/Denom I then use this YNew value to specify the displacement of the mesh at the next time step. I don't know why this set up doesn't work. If somebody can tell me anything about it, it would be very helpful. Thanks! Also can anyone tell me how the Mesh Velocity Y function calculates the mesh velocity? Is it the velocity change from the previous mesh or from the initial mesh? |
July 23, 2013, 16:43 |
Rep Power: 21 |
Check Mesh Velocity Y is giving you something sensible. I saw monitor points for this giving strange values recently.
Ansys 13 CFX problem on LInux Opensuse 11.4 | serendipity | CFX | 10 | August 7, 2012 03:24 |
Oscillating Cylinder in Parallel Flow: Analytical Solution | startingcfd | Main CFD Forum | 7 | March 23, 2012 05:49 |
Numerical oscillations in CFX with water boiling problem. | michujo | CFX | 4 | December 16, 2011 09:00 |
CFX Casting problem: Can it be done all in one? | jfasl | CFX | 1 | September 14, 2010 03:14 |
problem with oscillating cylinder | ammi | FLUENT | 0 | December 18, 2006 04:06 |
