total pressure at inlet
hi experts.
i'm simulating a rectangular channel with a weir which is placed in the middle of channel. I want to set inlet BC to total pressure. the flow is free surface and I now the total pressure but I don't know the depth of water at the inlet. discharge is also known. how can I set the volume fraction at the inlet? thanks in advance. |
If you do not know the depth at the inlet then how can you know the inlet pressure? You cannot account for the hydrostatic component.
Can you show an image of it?
But if this means your inlet is at a region where the flow has a significant velocity and a free surface, then it will probably be easiest to draw a chamber upstream to have the fluid entering at the correct height at zero pressure, and as a single phase. This will generate the exact conditions you want without numerical difficulties - but at the price of some extra mesh elements. |
thanks a lot.
