'Air Ideal gas' density problem
I had run a simulation of a stator-rotor combination, for which I had chosen the medium as Air Ideal Gas. After the simulations were done, when i generated report, i was surprised to see the considered density to be 2.23 kg/m-3. Shouldn't it have been 1.2256 kg/m-3? Also how do i rectify it to make it as 1.2256 kg/m-3
This looks like an error in your reference pressure. If the reference pressure is 1atm and you have a pressure of 1atm then you have 2atm absolute and densities about 2.2kg/m3.
Thanks a lot for your valuable reply. Could you please respond to the following questions too.
Should i take the reference pressure as 0 atm? So now do i have to re run the simulations? And how do i rectify it? |
You should put the reference pressure as a typical pressure in your domain. The documentation explains this.
And yes, you will have to redo the simulation as your current results are wrong. |
Thanks again. I would like to explain my problem definition-
I had specified the reference pressure as 1 atm Boundary condition: mass flow inlet to static pressure outlet So accordingly i plugged in the values as Inlet: Normal speed as 8.49 m/s Outlet: 1 atm as my turbomachine opens into atmosphere. So to rectify the problem of density, should i change the reference pressure as 0 atm or the outlet pressure as 0 atm or some other changes should be done. |
Outlet pressure should be zero, reference pressure should be 1 atm.
Either will work fine, as long at they add up to 1atm, but this way is better for round off errors and things of that nature. |
Thanks for your help.
