setup outlet boundary condition from steady state result
Old   July 17, 2013, 11:20
Default setup outlet boundary condition from steady state result
Shashwat
shaswat is on a distinguished road
Dear all
In my steady state analysis inlet is pressure (specified value) and outlet is velocity ( known value). later I want to run transient analysis. In this case, I would like to use the outlet as a pressure which is derived from the result of steady state at the outlet . please help me How to setup this condition?
Thank you
shaswat is offline   Reply With Quote
Old   July 17, 2013, 18:42
This is simple - just define the outlet as a pressure boundary and give it the pressure value from your steady state analysis. When you run the transient simulation use the steady state run as an initial condition.
Old   July 23, 2013, 03:53
Govindaraju
kmgraju is on a distinguished road
In my transient analysis, I set initial velocity and relative pressure with suitable value. I didn't run the steady state simulation.
I set inlet with velocity as a function of time and I set the outlet boundary condition as areaAve(Pressure)@outlet.
I need to clarify the following basic questions.
1. Is it correct setting ?( I dont' know the pressure value at the outlet. note that I set initial velocity and pressure when t=0)
2. In my setting, is the areaAve(Pressure)@outlet means free pressure boundary condition?
Thank you
kmgraju is offline   Reply With Quote
Old   July 23, 2013, 06:04
Do not specify the outlet as areaAve(Pressure)@Outlet! That is not going to work. You need to set it to a pressure value, probably just 0Pa.
What is a free pressure boundary condition? You have to set either the pressure or the velocity, and the other one is solved by the software.
Old   July 23, 2013, 09:01
Govindaraju
areaAve( pressure)@outlet works in my case. How?
can you please give one example I could not understand. How I can give the pressure value when the solution finishes steady state and start transient automatically?
( I may setup steady state and transient through configuration control )
Thank you
Old   July 23, 2013, 16:49
This is in effect setting the outlet pressure to the average it was last iteration. I have no idea what this is going to do, but I suspect you will have problems converging.
Have a look at the tutorial examples of how outlet boundaries are meant to be defined.
Radiation interface hinca CFX 15 January 26, 2014 17:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Outlet boundary condition colen CFX 6 March 8, 2010 22:49
