Home > Forums > CFX
Turbulence in a tube (large Re-range)
Old   July 24, 2013, 03:01
Default Turbulence in a tube (large Re-range)
chryzler is on a distinguished road
Hi guys,
I need your help clarifying some thoughts about modelling turbulence.
The setup:
I am modelling a flash evaporation in a pipe with small diameter (capillary). A subcooled refrigerant enters the capillary and due to pressure drop evaporates. Of course, the velocity increases with evaporation. The capillary is rough.
Some numbers:
Diameter of capillary: ~ 0.5mm
Length of capillary: up to 4m
Roughness: 1.5E-06m
Device-Reynolds-Number at Inlet: ~ 3000
Device-Reynolds-Number at Outlet: ~ 250000
Turbulence Model (SST, automatic wall function):
  • I think, there are two aspects that do not let me profit from the wallfunction and I rather need to resolve the boundary layer (y+ <=1 and at least 10 nodes in the boundary layer).
    • I have a transition from kind of laminar to turbulent.
    • I am especially interested in the near wall area, because the pressure drop is happening there. So I need to resolve the boundary layer even in the turbulent region.
  • That means I need to resolve the boundary layer in the whole pipe.
  • I have a large range of y+ and boundary layer thickness in my simulation.
    • y+ is largest for high Re.
      • Therefore my y+-values at the beginning of my capillary will be smaller than 1. Is this a problem?
    • Boundary layer thickness is largest for small Re. So I need to resolve my boundary layer up to this thickness.
Is my thinking flawed or is it reasonable? Are there aspects I am not considering? I would really appreciate your input. Thank you.
chryzler is offline   Reply With Quote
Old   July 25, 2013, 03:28
ghorrocks has a spectacular aura aboutghorrocks has a spectacular aura aboutghorrocks has a spectacular aura about
Is this steady state or transient? Why are you doing the model - what are you trying to learn?
Old   July 25, 2013, 03:51
I am doing a steady state simulation. On a coarse mesh, that means I do not resolve the boundary layer, it converges and I get qualitative good results. Experiments provide values for the massflow and temperature profile along the capillary.
It is my master thesis and I basically try to set up a simulation that matches the experiments. So that in future, perhaps they can simulate new configurations instead of doing the experiment.
Thread Tools
Trackbacks are On
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
High turbulence intensity wenfengxie FLUENT 1 April 16, 2010 13:00
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 05:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
