Modifying CFD-Post macro to output a time-varying expression at every timestep |
December 28, 2015, 15:19 |
I am running a TBR case whose solution file contains multiple timesteps, similar to a conventional true transient simulation.
I want to output an expression that varies with time at every timestep. What I've attempted so far: 1) record a session where I load timestep=0, create a table ("Table 1"), in field A1 enter the current time ("Time"), in B1 enter the time-varying expression ("modalF" in the following text), save the table to a .csv file; 2) stop recording and modify the .cse file into a macro and impose a for loop on the timestep; 3) load the macro (pasted in the end of the thread). This doesn't really work. The .csv file I got after running the macro has only one row with "Time" and "modalF" at the timstep=1 recorded at the first and second column. I'm guessing my syntax on the table fields ("A$i" and "B$i") might be wrong, but I don't know what the correct syntax is or how to fix it. Can somebody more experienced in CFD-Post macros please help? Thank you!! ----------------------------------- # Session file started: 2015/12/28 14:23:18 # CFX-17.0 build 2015.09.01-23.36-134860 # To avoid unnecessary file pre-processing and modifications, include # COMMAND FILE at the top of your session file. # If it is not included, the file is assumed to be older and will be # modified for backward compatibility. COMMAND FILE: CFX Post Version = 17.0 END DATA READER: CASE: Case trnExactTT_s1r2_02_timestep60_noHarFor_005 Current Timestep = 0 TBR OPTIONS: Timestep Sampling = Uniform Number of Timesteps = 240 END END END !$start = 1; !$finish = 5; !for($i=$start,$i<=$finish,$i++) { > load timestep=$i TABLE:Table 1 TABLE CELLS: A$i = "=Time", False, False, False, Left, True, 0, Font Name, 1|1, %13.7e,\ True, ffffff, 000000, True END END TABLE:Table 1 TABLE CELLS: B$i = "=modalF", False, False, False, Left, True, 0, Font Name, 1|1, \ %13.7e, True, ffffff, 000000, True END END TABLE:Table 1 Export Table Only = True Table Export HTML Title = Table Export HTML Caption Position = Bottom Table Export HTML Caption = Table Export HTML Border Width = 1 Table Export HTML Cell Padding = 5 Table Export HTML Cell Spacing = 1 Table Export Lines = All Table Export Trailing Separators = True Table Export Separator = Tab END >table save=N:/tmp_cfx_projects/test.csv, \ name=Table 1 !} # Session file stopped: 2015/12/28 14:24:10 |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
