Home > Forums > CFX
Export variables in CFD post
Old   July 30, 2013, 08:27
Default Export variables in CFD post
lorenz90 is on a distinguished road
Hi all, I am facing the problem of exporting in MATLAB/excel the value of the pressure in a set of points in my fluid domain. I have an excel file with the (X,Y,Z) coordinates of the points in which I am interested in calculating the pressure.
I searched everywhere for a procedure for exporting the pressure values, but it doesn't seem to exist. Therefor I registered, hoping that somebody more experienced had already resolved this complicated problem.
Thank you, Lorenzo
lorenz90 is offline   Reply With Quote
Old   July 30, 2013, 19:05
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
This is very easy to do.
In the post processor you put a point object at your XYZ location and use file/export with the point object to export the data.
You can also get the data during a simulation by defining a monitor point at your XYZ locations. Then you can see the variables at those points as the simulation progresses in the solver manager.
Old   July 31, 2013, 04:38
Thank you for replying ghorrocks.
I knew that option, my problem is basically that I have to export the data in more than 100 points; this technique, inserting manually the (X,Y,Z) of each point, would be very time consuming. I thought that it could be possible to use an excel file containing the coordinates to speed up the procedure. Do you know if it is practicable?
Old   July 31, 2013, 06:05
If you want the points from the post processor you can do it in a session file. A point cloud might also help.
If you want to do it in the solver then write a script to generate the CCL, or use a perl gizmo in the CCL to generate then CCL.
No need for you to manually enter anything.
Thread Tools
Trackbacks are On
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Plotting the Viscosity Contour in CFD Post ashtonJ FLUENT 3 June 2, 2015 12:06
Evaluate Heat Flux through plane in CFD Post hugo17 CFX 4 May 13, 2013 20:51
post graduate opportunity in CFD application in Military teguhtf Main CFD Forum 0 January 31, 2011 22:30
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
