-   -   Additional Variable (http://www.cfd-online.com/Forums/cfx/121713-additional-variable.html)
blade_CFX August 4, 2013 04:03
Additional Variable
Hi everyone.
I am modeling a gas-water free surface flow useing CFX-14. I have created a additional variable and the source exist in the water phase. The additional variable should only exist in the water phase,but finally I found it spread into the air phase, and this is not what I want.
How can I solve this problem?If anyone know the answer,please help me.I will be very grateful to you
ghorrocks August 4, 2013 06:00
What type of additional variable is it (what equation did you select to model it)?
Physically, why doesn't it spread to the air phase?
Wouldn't a diffusivity (assuming it is a diffusive AV, I am just guessing here) which has a value in the liquid but is zero (or close to it, like 1e-20) in air do the trick?
blade_CFX August 4, 2013 06:36
The type of additional variable is specific scalar and when the air.vf>0.5,the source will be 0. The transport type in water phase is Transport Equation,and in air phase,the transport equation is off.
The additional variable can be seen as a kind of chemical substances,and it can only exist in liquid phase.
ghorrocks August 4, 2013 07:24
How is it spreading into the air? Can you post an image? Or show a conservation balance?
