Home > Forums > CFX
CFX tutorial #22 keeps failing
Old   August 5, 2013, 04:24
Default CFX tutorial #22 keeps failing
siw
Stuart
siw will become famous soon enough
I'm trying the CFX version 14.5.2 tutorial #22 (Modeling a Ball Check Valve using Deformation and CFX Rigid Body Solver).
The simulation fails on timestep number 17 with messages about negative element volume. I've checked the step-by-step guide a few times to make sure I've not made any input mistakes, of which I did not find any. It also does not make any difference if it is run in serial or local parallel on a few cores.
Has anyone else had this problem?
I need to run this tutorial to get myself up to speed on this type of simulation as I need to solve something similar but with a linearly decreasing outlet pressure.
Thanks.
siw is offline   Reply With Quote
Old   August 6, 2013, 10:29
Matthias Voß
mvoss is on a distinguished road
export every timestep including the mesh and check where the mesh folds. @the bc or somewhere in the domain? How tight is the mesh displacement residual?
mvoss is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Simple pipe meshing - problems with y+ in CFX Keizers ANSYS Meshing & Geometry 23 January 15, 2015 09:00
Tutorial Files CFX Alessio CFX 2 May 4, 2012 12:36
[ICEM] CGNS mesh failing in CFX siw ANSYS Meshing & Geometry 4 March 14, 2011 14:53
ANSYS CFX Tutorial 7 Sam CFX 7 January 24, 2009 20:48
CFX Tutorial - Fluidized Bed Siaw Khur CFX 4 August 20, 2006 05:37
