Convergence problem
Old   August 6, 2013, 11:05
Default Convergence problem
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
Hello Friends,
I was trying to do a steady state simulation of T junction fluid mixing using SST model (Mesh size - 4.5 Million nodes). I used automatic timescale option for both the fluid and solid domains. When I ran the simulation and looked at the out file, I observed that all the equations are converged except the T-Energy equation. I do not understand the reason why this happens. I have attached two pictures of how the RMS residual value kept on increasing as the iterations progressed. Please suggest me as to what is the mistake that I am doing with this simulation. Thank you for your help in advance.
Regards,
Karthick
selvam2487 is offline   Reply With Quote
Old   August 6, 2013, 19:21
I should write a FAQ on this, it is a very common question.
This is due to the fluid timescales being much shorter than the solid time scales. So the time step the solver is using for the fluid is far too slow for the solid. You need to do two things to address this:
1) Include imbalances in the convergence criteria. Imbalances are the best way of picking up whether the global conservation is OK, and this is a key issue for CHT simulations where the coupling between the fluid and solid domain is not captured properly by residuals alone.
2) Use a solid time scale factor. And be aggressive - normally factors like 100 or 1000 are used. Feel free to use "Edit run in progress" to adjust this as the simulation progresses as you tune it to a value which converges quickly but not too quick and goes unstable.
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
