August 8, 2013, 08:22 |
Question about Relative Velocity
Ding Chao
Rep Power: 12 |
Hi,everyone
I am modeling a bubble flow useing CFX,and I need use relative velocity in CCL. I find that the slip velocity have no unit in the CFX reference_Guide,and I don't know this is why.Could anyone explain to me the question? Could I use this expression to calculate the relative velocity? Vr=sqrt((air.Velocity u-water.Velocity u)^2+(air.Velocity v-water.Velocity v)^2+(air.Velocity w-water.Velocity w)^2) If anyone know the answer,please help me! |
August 8, 2013, 18:58 |
Rep Power: 143 |
Seems strange. I would have thought slip velocity would be in m/s. Also make sure you are using the correct variable. There is "Slip Velocity" for ASM models, "particle Slip velocity" for particles, "Slip Velocity Magnitude".
There should be no need to calculate this, it should already be a variable in the solver. You just have to find the right variable name. |
August 8, 2013, 21:10 |
#3 | |
Ding Chao
Rep Power: 12 |
August 8, 2013, 22:11 |
Rep Power: 143 |
I don't understand it either. It might be a documentation mistake. Also we might be misunderstanding the variable. I am not sure which is the case.
August 8, 2013, 23:02 |
Ding Chao
Rep Power: 12 |
Thank you all the same!what do you think that if I use" Vr=sqrt((air.Velocity u-water.Velocity u)^2+(air.Velocity v-water.Velocity v)^2+(air.Velocity w-water.Velocity w)^2)"to calculate the relative velocity between gas and liquid?Is it accurate?
August 8, 2013, 23:26 |
Rep Power: 143 |
I suspect the value you get from your equation should be the same as Slip Velocity Magnitude, providing you are doing an ASM model. Is it the same?
Relationship between rotational velocity and torque question. | pa-dundas | FLUENT | 0 | September 3, 2011 10:04 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 08:42 |
Relative velocity in simpleSRFFoam | miku | OpenFOAM Running, Solving & CFD | 4 | November 4, 2008 10:51 |
Workbench Question - Relative Error Spacing | John S. | CFX | 0 | October 30, 2008 09:41 |
FIDAP/ FIPOST - velocity vector plot question ???? | Vitaliy Pavlyk | FLUENT | 1 | April 18, 2001 15:04 |
