August 15, 2013, 04:26 |
Curious about the inlet boundary marker.
Rep Power: 12 |
Hi all.
What's happening to the inlet boundary in picture 2. It has occured just once, never happened again. Wanna know why just in case. Thank you. |
August 15, 2013, 05:55 |
Rep Power: 143 |
It would help if you actually indicated what the relevant bit of your picture is. It is not obvious.
But I suspect it is the inlet boundary vectors point in weird directions. No, don't worry about this - but I would output your def file to CFD-Post and check the definitions of the boundary regions is correct. If it correct in CFD-Post then it is fine. |
August 15, 2013, 06:45 |
Rep Power: 12 |
Right, it's the weird inlet boundary vector marker.
Thakn you so much, Glenn. |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
get edge points for inlet boundary condition | pastilha | OpenFOAM Programming & Development | 2 | May 7, 2013 03:05 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
user soubroutine of inlet boundary conditions | Charlie Beghein | Siemens | 2 | August 30, 2002 02:03 |
