CFX post
Hello.
I simulated a 3d pipe in CFX The solver run finished successfully (with all time step). but when I open the cfx post, I can't see results for different tyime step. |
cfx post without results
At first I set up CFX solver for FSI problem then I change it (I removed the APDL Ansys) and only solved cfx solver for 3d pipe flow. the run finished successfully.
but I can not see result in CFX post. ERROR Variable 'Total Mesh Displacement' does not exist on 'wall'. ERROR Variable 'Total Mesh Displacement' does not exist on 'wall'. SEVERE An attempt to recover from a previous error has failed. The application is likely to be in an unstable state. I did solver setup successfully. what i do now? plz help me... |
By default the results file only contains the result at the end of the simulation. If you want any intermediate time steps you have to add them in the output options, under results file.
