-   -   Gravitational water flow in closed channel. (http://www.cfd-online.com/Forums/cfx/122793-gravitational-water-flow-closed-channel.html)
Szymon85 August 28, 2013 08:11
1 Attachment(s)
Hello everyone,
I have a problem with the modeling of two-phase flow in the channel as shown in the figure. Fluid intake is at the top of the channel and the outlet at the bottom (Z axis is vertical). One phase is water with a given volume flow rate, flowing down the channel. The second phase is the air moving freely. Everything is carried out under atmospheric pressure. I have very little experience in the use of CFD software, so I tried to use the tutorial "Free Surface Flow Over a Bump". I decided that this example is similar to my problem. But my case differs from that of the tutorial in the following way:
- Movement in 3D, rather than 2D;
- Flow of water under the force of gravity.
I loaded Bump2D.pre, deleted the tutorial model and loaded the mine. I removed the unnecessary borders leaving "inflow", "outflow" and "wall". Also introduced another change in one equation by adding value 85000Pa: DenH*g*DownVFWater*(DownH-y)+85000 [Pa]. Additional 85000 Pa to the pressure at the outlet of the channel is derived from the hydrostatic pressure of water, arising from the difference of levels (ca. 9 meters) between the inlet and the outlet.
Unfortunately, results are unsatisfactory. Streamline velocity of the water does not reach the outlet of the channel only breaks along the way. I started to change various parameters, creat flow pattern from beginning. I tried to change geometry, the boundaries, transient calculation. All of my efforts were to no avail. I received results similar to that described above or completely meaningless.
I was looking for some clues to topics in this forum and on the Internet, but it did not help. So I ask for some help, maybe another tutorial? What is wrong?
Attachment 24899
ghorrocks August 28, 2013 18:18
Can you show an image of what you are getting, and some pictures of your mesh.
Szymon85 August 29, 2013 06:34
Picture of the mesh:
http://i41.tinypic.com/5o8qxy.jpg
In mesh generator I choose:
“Defaults”:
- “Physics Preference” – “CFD”
- “Solver Preference” – “CFX”
“Sizing”:
- “Relevance Center” – “Medium”
Other options I left untouched.
Picture of the results:
http://i42.tinypic.com/jgnnzc.jpg
ghorrocks August 29, 2013 06:58
The problem is obvious - your mesh is far too coarse and the water is getting diffused away. You need a finer mesh across the section (but you mesh along the length is OK for starters). Once you have got the water flowing the full length of the pipe then you will need to do a sensitivity analysis on the section and length mesh resolution to get an accurate simulation.
Szymon85 August 30, 2013 10:09
Thanks for answer ghorrocks,
But I have antoher problem. Following your advice I thickened mesh by setting options: "Max face size" and "Max size" to 0,025m. Next I run calculations and recive error:
| Mesh Statistics |
| Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio |
| | Minimum [deg] | Maximum | Maximum |
| Default Domain | 30.0 ok | 38 ! | 10 OK |
| | %! %ok %OK | %! %ok %OK | %! %ok %OK |
| Default Domain | 0 <1 100 | <1 <1 100 | 0 0 100 |
Domain Name : Default Domain
Total Number of Nodes = 9576223
Total Number of Elements = 9914285
Total Number of Tetrahedrons = 198844
Total Number of Prisms = 13346
Total Number of Hexahedrons = 9125695
Total Number of Pyramids = 576400
Total Number of Faces = 399964
| Buoyancy Reference Information |
Domain Group: Default Domain
Buoyancy has been activated. The absolute pressure will include
hydrostatic pressure contribution, using the following reference
coordinates: (-7.24678E+00,-1.61470E+01, 2.70001E+00).
| Checking for Isolated Fluid Regions |
No isolated fluid regions were found.
CFD Solver started: Fri Aug 30 13:54:53 2013
| Convergence History |
| Timescale Information |
| Equation | Type | Timescale |
| U-Mom-Bulk | Physical Timescale | 2.50000E-01 |
| V-Mom-Bulk | Physical Timescale | 2.50000E-01 |
| W-Mom-Bulk | Physical Timescale | 2.50000E-01 |
| Mass-Water | Physical Timescale | 2.50000E-01 |
| Mass-Air | Physical Timescale | 2.50000E-01 |
| K-TurbKE-Bulk | Physical Timescale | 2.50000E-01 |
| E-Diss.K-Bulk | Physical Timescale | 2.50000E-01 |
OUTER LOOP ITERATION = 3 ( 1) CPU SECONDS = 1.016E+03 (1.910E+02)
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| *** INSUFFICIENT MEMORY ALLOCATED *** |
| ACTION REQUIRED : Increase the real stack memory size. |
| Details : |
| Requested space : 1735841844 words |
| Current allocated space : 2147483646 words |
| Current used space : 1055776224 words |
| Current free space : 1091707422 words |
| Number of free areas : 1 |
Details of error:-
Error detected by routine MAKDAT
CDANAM = A CDTYPE = REAL ISIZE = 1735841844
CRESLT = FULL
Current Directory : /FLOW/SOLVER/TIME-0/HYDRO_SS1
| Writing crash recovery file |
Details of error:-
Error detected by routine POPDIR
CRESLT = ILEG
Current Directory : /FLOW/NAMEMAP
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| Warning! |
| The ANSYS CFX Solver has written a crash recovery file. This file |
| has been saved as C:/rura |
| siatka_pending_tasks/dp0_CFX_Solution/Bump2D_001.res.err and may |
| be an aid to diagnosing the problem or restarting the run. More |
| details should be available in the solver output section of the |
| output file. |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
I've checked that error in google. Before run calculations I changed in solver tab value of "Memory Alloc Factor" to 1.3x, next time to 2x. Itdidn't work, so I try enter a specific value in "Detailed Memory Overrides" -> "Real Memory" -> <1800m>, because cfx request for space: 1735841844 words. After that I received error again.
I read that can be connected with mesh or setup errors, but before I refined the mesh I recived some results. Obviously that results were wrong, but simulations run from start to end without errors. Maybe the mesh is too small?
ghorrocks August 30, 2013 21:55
You have run out of RAM on the PC you are running on. Either make the simulation smaller (but this requires some skill to make it smaller and still retain the essential detail), install more memory or do a multi-processor run.
Szymon85 September 3, 2013 03:02
Hello everybody, especially ghorrocks,
I have questions, again J. I’ve made smaller simulation, like ghorrocks advised me. I changed min size of mesh to 0,05m. I also noticed that I had wrong variable in expressions in CFX-pre. In tutorial vertical axis is Y, in my simulation vertical is Z.So I changed it.
I run calculations which was ended without error and without warning about artificial wall at the outlet. So I thought everything is OK, but unfortunately not. Streamlines of water and air velocity looks like flow mixed, but should be separate. I also expected higher water velocity. Now, I don’t know what could be wrong, I have no idea. Earlier I have these streamlines separate. Below I put some simulation setup and streamlines of water and air.
http://i39.tinypic.com/11qsh8j.jpg
http://i41.tinypic.com/23wr6ko.jpg
http://i40.tinypic.com/28s7nt2.jpg
http://i43.tinypic.com/30jld9d.jpg
http://i43.tinypic.com/b5gsiu.jpg
http://i41.tinypic.com/2ajntx0.jpg
http://i44.tinypic.com/34inz36.jpg
http://i41.tinypic.com/2s0i79g.jpg
http://i43.tinypic.com/289ekg2.png
brunoc September 3, 2013 16:28
Phase.Velocity is calculated for the entire domain, regardless of whether the local volume fraction is 0 or 1. You want to plot the values for Superficial Velocity, which is volume_fraction * velocity.
To just look at the air-water interface, create an isosurface of Water.Volume Fraction = 0.5.
About your mesh, you need to refine it only near the wall. Check the meshing tutorials about 'Inflation'.
