Home > Forums > CFX
Simulating ater droplets with
Old   September 4, 2013, 03:22
Default Simulating ater droplets with
György Bicsák
gybicsak is on a distinguished road
Hi Everyone,
I would like to ask some help or advice; I'm trying to simulate a water separator device. The goal is to separate different moisture from the main airflow. The simulations of the ice particles have worked properly, but when I tried to model the behaviour of larger water droplets (with ~2.5 mm diameter), at the results, the water droplets were bounced all over the duct, instead of breaking up on the walls.
I used CFX with air ideal gas and water particle transport fluid settings, the buoyancy was set on with the gravitational acceleration and the reference density of the air, and the water buoyancy model was set to density difference, the fluid pair models were the following:
fully coupled; surface tension coeff.=7.56 N/M; Schiller Naumann drag force model was applied; with Schmehl breakup model and Schmehl Dynamic Drag Law; and for the particle Collision the COR was set to 0.1.
The airflow has high Reynolds number, the average velocity is over 80 m/s.
Could anyone suggest some modification to eliminate this bouncing effect?
Thank you for instance,
György
gybicsak is offline   Reply With Quote
Thread Tools
Trackbacks are On
Number of Droplets per Cell viv05 OpenFOAM 2 August 11, 2009 02:35
problem about droplets in porous cck CD-adapco 0 August 6, 2005 00:48
entrainment of droplets from liquid surface Elisabeth A. Hove Main CFD Forum 0 October 16, 2002 10:22
Simulating the generation of droplets through a no Bo Busk Jensen Main CFD Forum 3 March 18, 2002 10:22
Simulating Water Splash Using a Particle System Zi-Wei Chiou Main CFD Forum 0 March 4, 2002 07:33
