Home > Forums > CFX
Memory Error
Old   September 18, 2013, 03:59
Default Memory Error
mrittens is on a distinguished road
Hy,
can anybody help me with this kind of error? I am beginner and try a fluid flow throught a hollow zylinder as a heat source. That would be really nice!
Thx Michaela
Couldn't initialise lpnquery library
| Solver |
| ANSYS(R) CFX(R) Solver 14.5.7 |
| Version 2013.03.12-10.53 Tue Mar 12 11:06:45 GMTST 2013 |
| Executable Attributes |
| single-int32-64bit-novc8-noifort-novc6-optimised-supfort-noprof-nos|
| (C) 2013 ANSYS, Inc. |
| All rights reserved. Unauthorized use, distribution or duplication |
| is prohibited. This product is subject to U.S. laws governing |
| export and re-export. For full Legal Notice, see documentation. |
| Job Information at Start of Run |
Run mode: serial run
Host computer: xxx (PID:5424)
Job started: Wed Sep 18 09:54:13 2013
Details of error:-
Error detected by routine PEEKI
CDANAM = /LPNQ/DB/NREG
CRESLT = NONE
Current Directory : /FLOW/REGMAP
| ****** PROBLEM REPORT ****** |
| Subsystem: Input and Output |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
mrittens is offline   Reply With Quote
Old   September 19, 2013, 03:59
Default lpnquery library
Hy CFX-Community,
does anybody know what a lpnquery library means?
Thx and Greets Michi
Old   September 19, 2013, 05:53
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I have no idea. It is some weird thing you have set up. But as you have given no details about what you are doing or how you are doing it there is not much we can do to help.
http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F
Old   September 20, 2013, 04:11
Dear Horroks,
ok, true !
I am trying to simulate an air flow ( for temperature and velocity distribution) through a choke coil (dimensions: diameter: 2m, height: 2,5 m) The choke coil looks like a hollow cylinder with a wall thickness of 10 cm with a 3layers ( ring).Between every layer is a gap of 5 cm . Air flows througth it and cools the choke (like a convector) The boundary conditions of the surrounding (on a free ambient field)are inlet at the right side, outlet at the top, left side opening, back side and ground as wall. The choke material is aluminum with a source cooled by air flow. I have already got some results for similar conditions and body. I changed the geometry ( from 5 layers to 3 layers) and the mesh of an existing similar working simulation of a choke coil. But this time when I start the solver, it stops after a few seconds and I get this error. It even doesn't start mounting the mesh. Since the older version is working I thought about old parameters which cause the problem. Nevertheless I try to start the whole thing from zero and not from an existing file. This should help! Thanks!!! Michi
Old   September 20, 2013, 06:15
Can you post an image of what you are modelling and your CCL?
Old   September 25, 2013, 10:28
Smile
Dear Horrocks,
thanks for your help!!
I found error. There was a bad connection with the domains and interface connections in the setup. I turned the automatic default Domains and Interfaces off during setup generation and they where not shown. I went to Edit-->Options-->General and turned Default Domains on. Then I got some hints!
Thread Tools
Trackbacks are On
Compile calcMassFlowC aurore OpenFOAM Programming & Development 12 March 18, 2014 05:22
compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 2 August 30, 2013 07:42
Problem running perturbUCyl sen.1986 OpenFOAM 14 March 23, 2012 05:12
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
user defined function cfduser CFX 0 April 29, 2006 10:58
