September 20, 2013, 11:53 |
How to study noise in CFX
Mahmoud Gabr
Dear all
Could you help my in how to study the noise generated in piping system containing orifice from induced vibration due to turbulence using CFX. I am working with SST model. best regards M.Gabr |
September 21, 2013, 06:21 |
Rep Power: 143 |
What do you want to know about the noise? Are you looking for a full acoustics simulation (giving frequencies, acoustic dipoles and all that) or just a general idea if it is noisy or not?
September 26, 2013, 01:35 |
Mahmoud Gabr
Hi ghorrocks , thanks for your reply. I want to study the noise generated from turblance in order to optimize orifice design for low noise pressure reduction. this would require the frequencsies of waves generated due to pressure pulsation. But at first I want to know if this design is noisy or no. after that I may enter little bit deep study one of them.
September 26, 2013, 01:52 |
Rep Power: 143 |
Getting the full acoustics spectrum from CFX is difficult - You are going to need to do LES to get that. You can get simple estimates from simple turbulence models and looking at the turbulent energy, but accurate data will require LES.
September 26, 2013, 02:51 |
Mahmoud Gabr
So ghorrocks , Which factors should I depend on in my preliminary study and comparing orifice designs using current turbulence model SST . and should I make it transient simulation or I can continue using steady state simulation
September 26, 2013, 06:23 |
Rep Power: 143 |
You could infer noise level from turbulence intensity on a steady state model. But be aware that this is a very crude guide only. The only way you are going to get accurate results from this is by a LES model, and that is quite an undertaking.
October 1, 2013, 14:53 |
Mahmoud Gabr
Dear ghorrocks.
I found That using LES model can't happen in steady state and require transient. Could you illustrate how to inspect the turbulence in steady state , I wouldn't go deeply in studding noise , only need indicator that this design would be better in generating noise due to turbulence. |
October 1, 2013, 20:41 |
Rep Power: 143 |
Just a rough guess that turbulence intensity is linked to noise. So look at the turbulence intensity.
But you really should do some literature review on this to find the most appropriate way forwards. |
cfx, fsi, induced vibration, noise, sst |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 02:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
