Home > Forums > CFX
Error
Like Tree3Likes
  • 1 Post By ghorrocks
  • 1 Post By rameezib
Old   October 4, 2013, 09:55
Default Error
amin.z's Avatar
Amin
amin.z is on a distinguished road
hi
what's the meaning of this error:
"The CFX solver for system 'modelname' did not produce a results file"
when I run the solution, I see this error:
"The ANSYS CFX solver could not be started, or exited with return code 255:
No results file has been created."
amin.z is offline   Reply With Quote
Old   October 7, 2013, 13:19
Lightbulb hi Dear
saeed
saeed115 is on a distinguished road
maybe you have illegal copy of that software....check your software is active or not.you have to have an activate key...................G.luck
saeed115 is offline   Reply With Quote
Old   October 7, 2013, 17:44
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
This error does not imply it is pirated software. It simply means a simulation did not complete so not results file was generated. You would need to look into the details of the simulation setup to find what the error is.
amin.z likes this.
Old   October 8, 2013, 01:53
Rameez
rameezib is on a distinguished road
When this message pops out, close it, and have a closer view on the right hand section of the solver run, there you will get the exact error. Error might be due to some in appropriate boundary setting or due to output control setting. Thanks
amin.z likes this.
rameezib is offline   Reply With Quote
Old   October 8, 2013, 16:28
Default Thanks
amin.z's Avatar
Amin
Dear freinds!
thanks from you!
but my software license is valid and it works correctly
I checked the simulation again but it hasn't any result!
Old   October 8, 2013, 18:02
As I said, this error has nothing to do with licensing. You have a problem with your simulation setup. You would have to post more details about what you are doing if we are to help you.
amin.z likes this.
Old   October 9, 2013, 08:50
amin.z's Avatar
Amin
I'm modeling a simple 2D nozzle in CFX
geometry
http://www.cfd-online.com/Forums/att...1&d=1381322772
mesh
http://www.cfd-online.com/Forums/att...1&d=1381322794
setup
http://www.cfd-online.com/Forums/att...1&d=1381322811
Old   October 9, 2013, 17:39
We still have no idea what you are modelling - see: http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F
Old   October 13, 2013, 02:25
amin.z's Avatar
Amin
Dear ghorrocks!
as you said the error was due to incorrect settings in the simulation setup.
I checked it and solve this error
thanks for your help
good luck!
Old   October 25, 2013, 08:49
Thumbs up good luck amin
saeed
he simulate a symmetry airfoil...i think
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Saving ParaFoam views and case sail OpenFOAM Paraview & paraFoam 9 November 25, 2011 16:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
