Home > Forums > CFX
Turbulent models at high Reynolds number
Old   October 7, 2013, 01:17
Default Turbulent models at high Reynolds number
may
mayj is on a distinguished road
Hi
What are the major differences between LES, K-Epsilon and DES models in high Reynolds number in OBCs, in 2D and 3D method?
your reply will be highly appreciated.
Thanks
mayj is offline   Reply With Quote
Old   October 7, 2013, 06:00
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Please do not use jargon as people have no idea what you are talking about - fortunately Lance has nicely pointed that out in this thread: turbulent lodel at low Reynolds number
So a general comment abotu turbulence models:
* k-eps is a general purpose 2-eqn turbulence model. It works by modelling all turbulence as extra viscosity. I prefer the SST 2-eqn turbulence mode myself for general stuff, but the k-eps model is OK for many applications. Most engineering work uses either SST ot k-eps.
* LES is a sophistocated modelling approach where you split the turbulent spectrum into resolved and non-resolved components. This means you have to resolve the larger turbulence scales which means fine mesh, small time steps and low dissipation numerics. LES is not for beginners, so if you are asking what is LES then it is not suitrbale for you.
* DES is a combination of 2-eqn models and LES where the model attempts to use LES approaches in regions suitable for it, and a simpler 2-eqn model where that is appropriate. This is even more complex than LES so again not suitbale for beginners.
Thread Tools
Trackbacks are On
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 6 April 17, 2010 23:40
Calculate turbulent reynolds number in CFX Jervds CFX 2 May 11, 2009 09:18
low turbulent reynold number C-CARE CFX 4 March 12, 2004 07:36
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 14:46
