when I change the position of the arfiole cfx not converge?
Like Tree4Likes
  • 1 Post By ghorrocks
  • 1 Post By Lance
  • 1 Post By Lance
Old   October 12, 2013, 07:31
Default when I change the position of the arfiole cfx not converge?
wadoud
wadoud31 is on a distinguished road
hi evry one
I want to study the influence of several vanned distributor opening, so I changed the position of the airfoile, for the first case I got the solution, but when I changed the angle for the other cases the cfx did not converge, although I kept the same mesh (hex type , bloking the same) and the same boundary conditions.
Here the picture
best regards
thank you.
wadoud31 is offline   Reply With Quote
Old   October 13, 2013, 01:25
Did you generate new meshes for each position, or use something else?
It could be the first condition is attached flow and the simulation converges easily, but the others are separated flow and convergence is harder in this case it crashes. If this is the case you will need to improve mesh quality, smaller timesteps, double precision or a better initial condition.
wadoud31 likes this.
Old   October 14, 2013, 05:26
wadoud
thank you for reply
for the first case with a 13 ° angle I got the solution for several boundary conditions after 1500 itirations, but when I changed the angle of the blade either 15,18,20 or 25, after 3000 itiritions the residual target is higher than 0.001 and the convergence critiria is 0.00001
to remedy this
first I kept the same blocking and I associated the edges and vertices, after I checked the quality of the mesh.
second I used a new hex mesh (new blocking).
I kept the same boundary conditions.
but the problem persists.
if you have any ideas or solutions to this problem
I am very grateful for your help
Old   October 14, 2013, 05:40
Lance
Lance is on a distinguished road
So it doesnt converge when you increase the angle of attack? You probably get separation, and as Glenn said:
Lance is offline   Reply With Quote
Old   October 14, 2013, 05:53
wadoud
thank you for reply
how can I eliminate this problem to obtain the solution in the different positions of the blades
best regards
Old   October 14, 2013, 05:56
Lance
i'll quote it again.
Old   October 17, 2013, 05:25
wadoud
thank you for reply and I am very grateful;
I took your advice into consideration so I changed the mesh, timestep, double precision, I kept the same boundary conditions as the first case, but the problem persists. if you need more details I will disponoble.
best regards
Old   October 17, 2013, 05:34
Have a look in the literature for what other people have done for these simulations. Have a look at the meshes they use, the timesteps they need and the turbulence models they assumed.
If it is still not converging you need an even better quality mesh and/or even smaller timesteps.
The FAQ has more details: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   October 19, 2013, 05:19
wadoud
hi
thank you for your help and kindness
here some details
boundary conditions. (inlet): total pressure: 1.6258 bar, total temperature: 333K
(output of the rotor): Static pressure: 0
(wall) adiabatic
turbulence model used: RNGK-e
physical timescale: 3e-06 [s]
I used a hex mesh
-the height of the first cell was 0.1.
to remedy this
I have increased the number of nodes to 687375
-physical timescale becomes 1e-08 [s]
-the height of the first cell becomes 0.05
-Double-precision
-I check the quality of the mesh (see picture)
Old   October 20, 2013, 20:16
You are reporting just one mesh quality metric - and not a very important one at that.
The important ones are aspect ratio, volume ratio, face angle.
My post #8 still lists the important things for you to consider.
Old   October 23, 2013, 05:18
wadoud
thank you for your quick and accurate response.
concerning the quality of the mesh I attached a picture and I hope that you'll clear up the thing
Old   October 23, 2013, 07:11
Are you doing this steady state or transient? Separated airfoil flow is hard to model steady, so you might need a transient approach, and there is a chance you will need DES/SAS/LES.
Old   October 26, 2013, 04:39
wadoud
hi
i used steady state;
best regards
Comparison of fluent and CFX for turbomachinery Far CFX 52 December 26, 2014 18:11
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Phase Change in CFX derrek CFX 0 June 9, 2003 18:27
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
