Ratio of velocity in CFD-post
Old   October 15, 2013, 04:56
Default Ratio of velocity in CFD-post
bitacovir is on a distinguished road
Hi
My question is about the post-process of a simulation using CFX. I already run a simulation of wind blowing on a opaque wall. Now I would like to visualise de velocity regions behind of the barrier. With the option of CFD-Post contour on
a plane I can show contours of velocity. But the experiment that I am using as a base worked with a-dimensional expressions, where contours represent a ratio: U+ = U/Uref
U= ameliorated speed (leeward side of the barrier)
Uref= speed of reference before the barrier
Is it possible to express this function U/Uref with contours?
Regards
bitacovir is offline   Reply With Quote
Old   October 15, 2013, 05:33
Lance
Lance is on a distinguished road
Im not sure I understand you correctly, but I'll give it a shot.
Create an expression in cfd-post, e.g something like
Velocity/Uref
where Uref is an other expression you defined
Then create a variable of your first expression and plot it as the contour.
Lance is offline   Reply With Quote
Old   October 15, 2013, 06:25
Velocity/Uref
Thanks for your response.
What I mean: I want to replicate this isocurves:
this isocurves represent how much the wind speed changes around a building.
If the inlet wind is 5m/s and after the wall the speed decrease to 1.5m/s then, the region is represented as an area with the a-dimensional number of 0.3 (1.5/5).
If the area >1 that means the wind speed increases, if it is <1 the wind speed decreases.
Now, I don't know how to write the expression for the the wind speed after and before the barrier.
Old   October 15, 2013, 06:52
Generate the CFD-Post variable as Lance suggests. This is quite simple to do, have a look at the tutorials if you need help on how to introduce post processing variables.
Then put a plane through your domain and generate a contour plot on the plane of your variable and that will generate the equivalent plot.
Old   October 16, 2013, 06:39
OJ
oj.bulmer will become famous soon enough
On the same note, is it possible to show those values in different regions in the contour like the figure above? I tried once doing that but couldn't figure out how to do that.
OJ
oj.bulmer is offline   Reply With Quote
Old   October 16, 2013, 06:50
I think you have to do that manually using text objects. I cannot think of a way of doing it automagically.
Old   October 16, 2013, 07:18
OJ
... I cannot think of a way of doing it automagically.
Freudian?
Old   October 16, 2013, 17:26
Not at all. It is a very useful term: http://www.urbandictionary.com/defin...=automagically
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
Plotting the Viscosity Contour in CFD Post ashtonJ FLUENT 3 June 2, 2015 12:06
Velocity in porous domain in CFX post Chander CFX 5 May 20, 2015 04:12
Parallel process & CFD POST jypark FLUENT 2 August 14, 2013 23:49
How to visualize Output Equation Residuals in CFD Post rubin4ik CFX 2 June 22, 2011 06:37
