I met one problem about CFX-solver
Old   October 18, 2013, 02:05
Default I met one problem about CFX-solver
Ian
windfire is on a distinguished road
I met one problem about CFX-solver, the output file shows
COEFFICIENT LOOP ITERATION = 7 CPU SECONDS = 2.744E+03
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom | 1.18 | 3.7E-03 | 7.7E-01 | 6.3E-04 OK|
| V-Mom | 1.22 | 5.7E-03 | 1.3E+00 | 2.8E-04 OK|
| W-Mom | 1.01 | 5.1E-03 | 5.2E-01 | 4.6E-03 OK|
| P-Mass | 1.07 | 7.3E-04 | 2.0E-01 | 11.3 1.0E+00 F |
| ****** Notice ****** |
| A wall has been placed at portion(s) of an OUTLET |
| boundary condition (at 8.5% of the faces, 7.8% of the area) |
| to prevent fluid from flowing into the domain. |
| The boundary condition name is: out2. |
| The fluid name is: Fluid 1. |
| If this situation persists, consider switching |
| to an Opening type boundary condition instead. |
Parallel run: Received message from slave
Slave partition : 2
Slave routine : ErrAction
Master location : RCVBUF,MSGTAG=1033
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
Slave partition : 2
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
Who could help me solve with this problem?
Many thanks in advance!
windfire is offline   Reply With Quote
Old   October 18, 2013, 04:02
S.Bogoda
sakurabogoda is on a distinguished road
Extend your outlet from the inlet.. and hope this will help you.
http://www.cfd-online.com/Forums/cfx...-s-outlet.html
this is a very common problem here and you can find answers and details by using Search.
sakurabogoda is offline   Reply With Quote
Old   October 18, 2013, 04:41
Lance
Lance is on a distinguished road
The error is due to an owerflow:
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Lance is offline   Reply With Quote
CFX solver problem Lamine CFX 4 June 14, 2013 17:43
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
ERROR #002100056 CFX FSI problem Hongdao CFX 0 November 10, 2010 03:58
CFX new user, problem with solver and PRE settings Vijesh Joshi CFX 1 March 13, 2006 22:42
