Home > Forums > CFX
linear mesh motion in CFX
Like Tree1Likes
Old   April 11, 2014, 08:46
Bruno
brunoc is on a distinguished road
Look for special characters in your model and/or path to your file. Some parts of CFX don't handle them well, so be sure to only use [a-z][A-Z][0-9] on your names. Steer clear of things like , , , , , etc.
Or just post your entire CCL here so we can take a look at it.
brunoc is offline   Reply With Quote
Old   April 14, 2014, 17:37
ali
alinik is on a distinguished road
I am not using any special charcters in names. I do not know what is causing this error. I have attached the CCL. Please have a look if you had a chance.
alinik is offline   Reply With Quote
Old   April 14, 2014, 18:57
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
A comment:
No need to use things like sin(43.7*pi/180). Much better to just say sin(43.7[deg]) and let the solver handle the units conversion.
Can you post your output file as well? And an image of what you are modelling.
Old   April 14, 2014, 19:31
ali
the rods are moving upwards, all surroundings are wall
Old   April 14, 2014, 19:38
ali
Thanks for the comment Glenn. The rods are moving upwards, all surroundings are wall. Since I get the error, I cannot produce output files
Old   April 14, 2014, 20:34
Have you done the debugging suggested in this FAQ: http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F
Old   April 15, 2014, 12:49
ali
I could not find the error I am having in the post you mentioned Glenn
Old   April 21, 2014, 17:37
ali
Ok guys, I contacted the ANSYS support team and they told me that since the rods are extended all the way to the boundaries it fails to remesh. Now I have left a very small gap on each side of the rods and it is supposed to run just fine as ANSYS guy told me.
it works fine and even remeshes the domain in the first loop but then I receive this error
| An error has occurred in cfx5solve: |
| Error reported by IO module: iif_open: the file is not in CFX-5.x |
| format |
| Error reported by IO module: iocnt: open the primary file failed |
| An error has occurred in cfx5solve: | +--------------------------------------------------------------------+
| format |
| Error from IO module while opening |
| /scratch/nikp11/WD/BRYAN/test2_001.dir/project1.uns.bak: |
| "iocnt: open the primary file failed" |
| IO_BAD_FILE(20): Invalid def/res file. File could be corrupted. |
| WriteToFile failed - dataset write filed |
any ideas?
Old   April 24, 2014, 18:04
ali
Guys is there any scripting example for remeshing problems?
I need to know do I have to have the commands for writing the mesh in the script?
more importantly
If each time the position of the moving object is going to change and in the script ICEM is going to put the object in its original location how it is supposed to mesh the new domain?
All I am saying is that in the script the location of the moving object is FIXED so in every timestep the ICEM is going to put the box right in the same location as before. Isn't it? I think that is why I am having awful number of errors.
That is why I need to take a look at some scripts that have been written for this case.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Dynamic mesh motion using CFX Anant CFX 5 February 27, 2014 08:17
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 13:22
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
