Home > Forums > CFX
Heat Transfer Alaysis
Old   October 20, 2013, 23:10
Arrow Heat Transfer Alaysis
Praveen Kumar
kumar.praveensp is on a distinguished road
Send a message via Skype™ to kumar.praveensp
Dear Friends,
I am working on heat transfer analysis of an heat exchanger.
I tried it for the first time and am not sure of the result which I obtained. Needed some guidance from u friends. I don't know what went wrong while deriving conditions.
Details:
* FinTube Heat Exchanger (without fins)
* Fluid is Oil in pipe, inlet temperature is 215 F
* Gas flows over the pipe from bottom to top whose inlet temperature is 922.5 F
*In my result I don't find any variation in temperature at both the outlets.
Note : I have attached the image files of my problem
Thanks in Advance
kumar.praveensp is offline   Reply With Quote
Old   October 21, 2013, 05:17
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
What sort of variation are you expecting to see? Your images seem to show all fluids equalising out at about 767K - is there something wrong with this?
Old   October 21, 2013, 05:58
Post
Praveen Kumar
[QUOTE=ghorrocks;458016]What sort of variation are you expecting to see? Your images seem to show all fluids equalising out at about 767K - is there something wrong with this?
Thank You For the concern Sir,
I need to find the temperature variation at the outlet of the pipe,In my result the temperature is same as gas temperature, is that right? I feel it dont
Old   October 21, 2013, 06:05
This can happen depending on the heat exchanger operating point. I say again - what do you expect to happen? Are you trying to match experimental results?
Old   October 21, 2013, 06:32
Praveen Kumar
[QUOTE=ghorrocks;458037]This can happen depending on the heat exchanger operating point. I say again - what do you expect to happen? Are you trying to match experimental results?
yes we trying to compare it with experimental results
Thread Tools
Trackbacks are On
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
