ERROR: Invalid pitch angle on domain interface |
October 23, 2013, 05:21 |
Rep Power: 12 |
I cant run my simulation there is an error showing "CFx Solver does not produce a result ". when i check the output file it says "Invalid pitch angle was found on side 2 of domain interface.
How can i solve it ?? |
October 23, 2013, 07:11 |
Rep Power: 143 |
By fixing up the pitch angle. Looks pretty obvious to me.
October 24, 2013, 07:01 |
Rep Power: 12 |
I had given the value to be 1. I am doing transient analysis of single nozzle pelton turbine. i tried to change value to angle and gave 40 and 45. it then said divide by zero error.
what is the physical significance of the pitch angle? |
domain interface, invalid pitch angle |
[ICEM] interface problems_2D mesh with a rotational domain inside a static domain TO FLUENT | HHOS | ANSYS Meshing & Geometry | 1 | September 26, 2013 13:25 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Fluid-2 domain interface | harry | CFX | 0 | November 6, 2004 06:01 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
