Home > Forums > CFX
simulation of wall with holes
Old   October 23, 2013, 21:48
Default simulation of wall with holes
bitacovir is on a distinguished road
I am trying to simulate wind blowing on a flat wall. 1.6m height and 4m length. (50mm thick).
Following several tutorials I could generate a mesh and insert a inflation layer on the surface of the wall. When I run a simulation the chart of convergence showed that RMS Residual Error Values have reduced to less than e-04 that I understand is good.
Then, I change the wall geometry with a wall with same size but including a vertical gaps producing a 20% of porosity in the wall.
I use the same parameters to produce the mesh and the inflation, but when I run the simulation the convergence remains between e-03 and e-04.
What do you think I can change or improve to results? Why is different when the surface of the geometry has holes?
bitacovir is offline   Reply With Quote
Old   October 24, 2013, 05:28
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   October 24, 2013, 06:54
Originally Posted by ghorrocks View Post
Thanks. I didn't know about this FAQ
Thread Tools
Trackbacks are On
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 8 December 3, 2013 17:51
Airfoil simulation using moving wall Alejandro NUMECA 9 November 4, 2008 03:00
How can i run a FSI simulation of a rotation wall romance CFX 0 November 27, 2007 08:35
small size holes simulation brian ko Phoenics 5 October 22, 2001 12:53
