October 24, 2013, 06:36 |
Periodicity
Rep Power: 12 |
What is the effect of rotational periodicity in the transient analysis?? I tried with opening for the rotational periodicity mentioned area for first (my simulation didn't run got error saying divide by zero.. )
later i gave the region as rotational periodicity then every time i run the simulation there is a message called "CCl2flow.exe has stopped working" |
October 24, 2013, 07:44 |
Rep Power: 143 |
Rotational periodicity is a mathematical link between faces on a domain which mimic rotational periodicity. It is a little hard to explain - If you do the CFX tutorials it might make more sense.
Also the FAQ may help: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F |
October 24, 2013, 21:47 |
Rep Power: 12 |
what is the cause of crashing og CCl2flow.exe?
October 24, 2013, 21:48 |
Rep Power: 143 |
No idea. That is the gizmo which reads the CCL so it looks like something is invalid in your CCL.
October 25, 2013, 01:56 |
Rep Power: 12 |
I tried to run other simulations they are okay. but when i particularly run this one the ccl2flow stops working.
October 25, 2013, 04:52 |
Rep Power: 143 |
As I said, the error suggests your CCL is invalid, or it is not linked to your mesh correctly. I would regenerate that def file in CFX-Pre.
ccl2flow.exe, divide by zero, periodicity |
[ICEM] How define periodicity correctly in ICEM | FJSJ | ANSYS Meshing & Geometry | 18 | January 11, 2023 11:07 |
[ICEM] ICEM periodicity specification | robboflea | ANSYS Meshing & Geometry | 18 | November 11, 2014 14:51 |
Periodicity lost during quater ogrid blocking | syler3321 | ANSYS Meshing & Geometry | 0 | October 17, 2011 23:24 |
Periodicity in CFX | Sam S | CFX | 2 | August 27, 2007 00:59 |
translational periodicity | wasim | CFX | 0 | May 13, 2006 13:34 |
