User_get_mesh_info
Dear All,
I'm working on a 3D blade having structured mesh around blade wall. In my work I'm using a Fortran subroutine that is compiled to CFX (User CEL). I need to get access to the elements coordinates or Element-to-vertex Connectivity. Based on CFX documentation it is possible by calling "USER_GET_MESHDATA" subroutine where the array shape is defined as CrdFc (ISFC_S:ISFC_F, NDIM) or KVxEl (ISEL_S:ISEL_F,NVxEl). However, I think first I need to call "USER_GET_MESH_INFO" subroutine to obtain the values of integer variables defining these arrays. As you know The general form of this subroutine is : SUBROUTINE USER_GET_MESH_INFO (WHO,ACTION,CERACT, & WHEN,CZONE,LOCALE,CDIR,CRESLT, & CZ,DZ,IZ,LZ,RZ) By calling "USER_CALC_INFO", I find that in my case: CZONE='ZN1' LOCALE='BELG3' moreover I set ACTION='GET', CERACT = 'STOP', WHEN = 'LATEST' and CDIR = ' '. So the code generates a directory name of "MESH_INFO/ZN1/BELG3" in which to place the data. So, finally this is what I'm trying to run: #include "stack_point.h" #include "MMS.h" call USER_GET_MESH_INFO ('YDISP','GET','STOP', & 'LATEST','ZN1','BELG3',CDIR,CRESLT, & CZ,DZ,IZ,LZ,RZ) I suppose I need to use PEEK facilities at this step in order to obtain the integer values (as stated in documentation) such as : NEL,NVX,NDIM,ISFC_S,ISFC_F etc. But I have not been able to use these facilities properly. unfortunately the available examples couldn't help me much as they were not clear to me.Could you please help me through? is my procedure right? if so, Which PEEK facility I need to use and how? Thanks in advance. Araz |
Hello.
As I understand to get NEL, NVX, NDIM you need to call USER_GET_MESH_INFO with empty locale, because these are zonal parameters. Next, as all values that you want are integer, call PEEKI to get them. For example: Code:
CALL USER_GET_MESH_INFO ('YDISP','GET','STOP','LATEST','ZN1','',CDIR,CRESLT,CZ,DZ,IZ,LZ,RZ) |
Dear Antanas,
Thanks a lot for your reply, it was quit useful and by doing a very little modification I could run your suggestion successfully. However, I think I have problem in identifying the variables and parameters to be called by these subroutines, for example consider the general form of "PEEKI" subroutine: SUBROUTINE PEEKI (CDANAM, JADRES, IVALUE, CERACT, CRESLT, IZ) where according to CFX documentation, "CDANAM" is the name of the data area. assume I want to obtain "NVX". So I replace "CDANAM" with: "/USER/'//CDIR//'/NVX" which is the place where the value of "NVX" is stored. I get it. Then is "JADRES" which is defined as array entry. In my case we replaced it by "IONE" (=1). Is that the number at which CFX starts to count the value (or number) of the integer variable (here the number of nodes)? and it should always be 1? Now, apart from this, USER_GET_MESH_INFO is useful to obtain integer, scalar data and not arrays which is my actual purpose of following this procedure. Are the arrays and REAL parameters such as coordinates already stored at the same data area (CDANAM= "/USER/'//CDIR//')? or they need to be stored separately using other functions? So, for me, to find the face coordinates i.e., CrdFc (ISFC_S:ISFC_F, NDIM), it is not just enough to call "USER_GET_MESHDATA" since pointers to faces are not obtained yet. Is that correct? I suppose, before calling "USER_GET_MESHDATA", it is necessary to call "PEEKR" and/or "LOCDAT" subroutines. General form of LOCDAT: SUBROUTINE LOCDAT (CDANAM, CDTYPE, CERACT, ISIZE, JADRES, CRESLT) I tried "CALL LOCDAT('/USER/'//CDIR//'/CrdFc',CDTYPE,'STOP',ISIZE,CrdFc &,CRESLT) but it ddin;t work and got the following error message: "Error detected by routine LOCDAT CDANAM = /USER/MESH_INFO /CrdFc CRESLT = NONE Current Directory : /FLOW/BOUNDCON/ZN1/BCP1/VARIABLES/MESHDISP" I also tried "CALL LOCDAT('CrdFc',CDTYPE,'STOP',ISIZE,CrdFc &,CRESLT)" but didn't work as well and I got the message: "Error detected by routine LOCDAT CDANAM = CrdFc CRESLT = NONE" Then I tried "PEEKR": CALL PEEKR('/USER/'//CDIR//'/CrdFc',1,CrdFc,'STOP', &CRESLT,IZ) but again error: Error detected by routine PEEKR CDANAM = /USER/MESH_INFO /CrdFc CRESLT = NONE Any advice and suggestions is highly appreciated. Thanks for your time. Regards, Araz |
In order to squeeze my previous post:
1- How could I obtain the values of "CrdFc (ISFC_S:ISFC_F, NDIM)" and "KVxEl (ISEL_S:ISEL_F,NVxEl)" using USER_GET_MESHDATA? (considering that I have already obtained all the integer variables which identify these arrays) 2- Do I need to call PEEKR and/or LOCDAT and/or any other specific routine to identify these arrays? 3- What strings do I need to to choose when calling these routines? e.g., CDANAM, NVAR,pVAR ... Thank you again, Araz |
CALL USER_GET_MESHDATA ('Coordinates','Vertices','RETURN','STOP',CRESLT,NVAR,pVERTCOORD, CZ,DZ,IZ,LZ,RZ) Code:
DO I = 1,NVX Code:
CALL SET_MY_ARRAY(MYCOORDS,RZ(pVERTCOORD),NVX,NDIM) Code:
SUBROUTINE SET_MY_ARRAY(OUTP,INP,NVX,NDIM) |
1 Attachment(s)
Dear Antanas,
I apologize because of not being able to reply and thank you earlier for your time and help. I implemented what you said and got the result. the only difference is that, (based on the result that I got and plotted), the first "NVX" number of values corresponds to the X coordinate of nodes, the next "NVX" number of values represent the Y coordinates and the last "NVX" numbers are the Z coordinates. In my case which was obtaining the face centers: RZ(pFACECOORD +(0:ISFC_F-1)) = X coordinate of face centers RZ(pFACECOORD +(ISFC_F:ISFC_F*2-1)) = Y coordinate of face centers RZ(pFACECOORD +(ISFC_F*2:ISFC_F*3-1)) = Z coordinate of face centers However, I will need one more mesh related information to reach my goal. The final purpose is to get access to the nodal values of the nodes located on each streamwise gridline. For example consider the attached figure. As you see There are 14 streamwise grid lines (in Z direction) over the blade from hub to tip. I need to get access to the nodal values of each one of these gridlines separately. So far, I have obtained the coordinates of the nodes and face centers. However, I have not been able to capture which 4 nodes belong to which face (in the other word each face is consisted of which nodes), or which node belongs to which gridline. Do you have any suggestions for this too? Again thank you so much, Regards, Araz |
