Home > Forums > CFX
Momentum loss with temperature increase
Old   October 29, 2013, 10:34
Default Momentum loss with temperature increase
siw
siw will become famous soon enough
I need to model the airflow through a system which includes the air passing through a heater, basically a mesh screen. I plan to treat the heater as a porous domain or a sub-domain with the momentum loss model, both are the same basically, because the heater will cause a pressure drop (it'll also be modelled with the heater switched off).
I would also like to include the temperature increase of the air due to it passing through the heater. I've had a quick look at what CFX offers but the only thing I can see is a heat source. But the only data I have about the heater is the inlet and outlet air temperture at a single volumetric flow rate, nothing else.
Anyone have recommendations on modelling this?
Thanks.
siw is offline   Reply With Quote
Old   October 29, 2013, 11:29
Edmund Singer P.E.
singer1812 is on a distinguished road
The only thing your data point fixes is the q = mdot*cp_air*(Tout - Tin) that the heater imparts into the flow. You really dont even need that data point if you assume all the heat goes into the flow and that it is evenly distributed from your domain.
Sub domain source:
heat /unit volume = q/(subdomain_volume)
The q is up to you, I assume based on the operation of the heater.
singer1812 is offline   Reply With Quote
Old   October 30, 2013, 09:10
siw
Thanks for the information Edmund.
Thread Tools
Trackbacks are On
Interface heat or temperature increase siw CFX 1 October 2, 2013 13:24
Static Temperature / Opening Temperature JulianP CFX 6 March 23, 2013 17:03
Free stream temperature saharesobh FLUENT 1 October 11, 2012 20:52
Temperature loss in compressible solvers in high speed flows vkrastev OpenFOAM Running, Solving & CFD 0 May 14, 2011 04:41
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
