October 31, 2013, 04:09 |
ParaSolid SW file import to CFX
Stine Olsson
Hi I am a mech. eng. student.
I have a project where I am simulating a membrane crossflow with a cheramic membrane. I would wont to simulate this in ANSYS CFX. I am relatively new to CFD and have problems getting started. I have tried to import a parasolid geometri from Solidworks showing just one monotube, with respectively the substrate, first coat and a second coat layer plus the fluid within the tube. My problem is that in Solidworks the 3 layers and fluid part merge into one which is how CFX is registrering it as well. So how do I create a geometri of the membrane that has respectively a fluid part, a substrate layer and two coat layers. I do not know how to create the geometri in CFX which is why I am trying the Solidworks option. Hope that are someone that may be able to help. |
October 31, 2013, 11:37 |
Kevin Hoopes
Rep Power: 16 |
Are they separate bodies in SolidWorks?
October 31, 2013, 16:19 |
Rep Power: 143 |
This sounds like a solidworks problem, not a CFX/ANSYS problem. Check that your geometry resolution tolerance is fine enough to resolve the features you are modelling.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
