Error message after solver finished the run
1 Attachment(s)
Dear friends,
I simulating a transient flow with 100 time step and results frequency of 2 time step, means that I have 50 output files. When the solver finishes the solution , there is an error message (attached) and the post prospering can not be updated. All of the results are in "pending" folder but I guess can not be moved to the main folder. I have started the run some couple of time , every time the same problem. I would appreciate if you can help me on this problem. Thanks Mehdi |
