November 16, 2013, 03:28 |
Balance of Heat Transfer
AKHILESH S L
Rep Power: 12 |
i am modelling a heat exchanger of concentric tube type with counter flow. temperature difference is obtaining for the two fluids. but when calculating the total Q (Q=m*Cp*delta(t)) it is not equal for the two fluids. the intermediate metal is aluminum. what may be problem. i calculated the heat absorbed by the metal but is very low. also during steady state analysis it wont be a problem right? i have not modeled any convection, radiation or conduction. so there is no chance of any other heat transfer losses. please help me in resolving this issue. outer walls are given as adiabatic only and heat transfer interface is created for the two layers between the to fluids and the wall.
November 16, 2013, 05:11 |
Rep Power: 143 |
Sounds like a simple inaccurate simulation to me: FAQ - http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Particularly read the bit about convergence tolerance sensitivity |
November 16, 2013, 06:22 |
AKHILESH S L
Rep Power: 12 |
thank you Glenn for your response. but the thing is i am getting correct results and correct energy balance when the dimensions of my outer fluid layer is increasing. in my real problem the outer fluid layer thickness is 0.3mm. but when i change this to atleast 1m i am getting accurate value. one more thing my convergence criteria is given 1e-6 . it is too low na? can you show me a accurate converging lines figure in the solving figure? is the lines should be in parallel itself? my lines are not parallel but inclined one.
November 17, 2013, 07:05 |
Rep Power: 143 |
Sorry, I do not understand your last post. What is the thickness of the outer fluid layer you wish to model?
The documentation has a good description on what convergence means, and how to judge it. |
November 21, 2013, 23:47 |
AKHILESH S L
Rep Power: 12 |
in actual problem the outer layer thickness is 0.3 mm . but when modelling with this low thickness energy balance is not obtaining. when modelling with atleast 1 mm energy balance is obtaining. what may be problem? meshing is not proper i think so. while modeling fluid-solid interface inflation layer thickness is a problem i don't know how to give proper inflation in the interface. please help me in this problem
November 22, 2013, 04:31 |
Rep Power: 143 |
Try the geometry and meshing forum for questions on meshing.
If you are not getting the energy to balance then converge tighter. You should use imbalances as part of your convergence criterion for CHT simulations like this. |
heat exchanger, heat transfer balance |
Display Modes | |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Heat Transfer mechanisms | tafaugl | CFX | 1 | November 7, 2012 18:46 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
