Curved flow
Old   December 25, 2013, 22:08
Default Curved flow
Govindaraju
kmgraju is on a distinguished road
Dear all
My geometry has a curved pipe. the fluid entering +y direction (inlet as pressure). The outlet axis coordinate has (+x,-y) coordinate. So I introduced outlet (velocity) as Normal to the surface.
My question is if I rotate the component in the workbench so that the outlet is along X axis, How about my result in this case and previous case? is it same or different?
Thank you
Govind
kmgraju is offline   Reply With Quote
Old   December 26, 2013, 00:13
If you rotate the thing and do the same simulation you should expect the same result, just rotated. Is that what you are asking?
Or are you asking if you can use a previous rotated simulation as an initial condition? That is harder - in general, no, you cannot.
Old   December 26, 2013, 05:31
Govindaraju
Thank you Very much
I have another question. Please find the attached pictures. I am confusing about turbulence model.I run the steady state first and then transient . My inlet is pressure and outlet is velocity . I am expecting low Reynolds turbulence occurring near the curve and the area restriction . Is my solution is converged or not.I tried SST model .I also tried tried many models like RNG K-epsilon, K-omega etc , but the solution doesn't meet the convergence criteria 10^-4
Give your advice
Thank you
Govind
Old   December 26, 2013, 05:46
FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   December 26, 2013, 10:36
Govindaraju
Dear all
please find the following statement.U Mom, v-mom, Vmom, P-mass all are F.
This will start from 70th iteration t0 100 iteration . what does it mean.
Thank you
| U-Mom | 1.00 | 3.8E-04 | 9.5E-03 | 1.0E+00 F |
| V-Mom | 1.00 | 3.8E-04 | 7.5E-03 | 1.0E+00 F |
| W-Mom | 1.00 | 5.2E-04 | 1.7E-02 | 1.0E+00 F |
| P-Mass | 1.00 | 1.0E-04 | 5.4E-03 | 8.9 1.0E+00 F |
| K-TurbKE | 0.99 | 8.7E-05 | 4.4E-03 | 5.7 8.1E-02 OK|
| O-TurbFreq | 1.05 | 8.3E-06 | 8.6E-04 | 10.5 5.8E-07 OK|
| Rethetat | 2.17 | 6.1E-04 | 2.8E-01 | 5.9 1.0E-02 OK|
| Intermit | 0.77 | 6.0E-05 | 1.4E-02 | 5.7 5.8E-03 OK|
OUTER LOOP ITERATION = 88 CPU SECONDS = 2.320E+03
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| K-TurbKE | 0.99 | 8.6E-05 | 4.3E-03 | 5.7 8.0E-02 OK|
| O-TurbFreq | 1.03 | 8.6E-06 | 9.1E-04 | 10.5 5.3E-07 OK|
| Rethetat | 1.16 | 7.1E-04 | 2.6E-01 | 5.9 1.1E-02 OK|
| Intermit | 1.06 | 6.4E-05 | 8.7E-03 | 5.7 7.1E-03 OK|
Old   December 27, 2013, 05:34
This is explained in the documentation. It means the linear solver is diverging. Check that your simulation is correctly setup, improve your mesh quality, use smaller time steps, double precision numerics or a better initial condition.
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 17:10
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 22:08
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 23:08
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
