inflation layer, domain interface
Old   November 22, 2013, 00:42
Post inflation layer, domain interface
AKHILESH S L
AKHILESH S L is on a distinguished road
hi friends,
while modelling a domain interface between fluid and solid, what is the way of giving inflation layer to the interface? is is essentially to give both the solid and fluid model? or is enough for giving the inflation to fluid layer only? which is the best way?
AKHILESH S L is offline   Reply With Quote
Old   November 22, 2013, 05:34
In a solid you only need a mesh fine enough to resolve the gradients. In steady state the gradients are very gentle so quite a coarse mesh is often good enough. In transient simulations the mesh size required will depend on the gradients created by the temperature changes over time.
But at the end of the day you should always do a mesh sensitivity check on these things and work out exactly what your simulation requires for the accuracy you desire.
Old   November 22, 2013, 11:26
Post
AKHILESH S L
thank you ghorrocks
for solids it is ok and i am doing a steady state analysis only. so for fluid layer inflation is necessary in solid-fluid interface right? i need to get the correct energy balance that's why i am in a confusion.
Old   November 23, 2013, 05:39
Energy balance is determined by how tight your convergence is. If you have an energy imbalance then just converge tighter. But to get the energy flow right you need an accurate simulation and that implies inflation layers, fine mesh and good emsh quality.
Old   November 25, 2013, 01:44
Post
AKHILESH S L
THANK YOU ghorrocks i need the correct energy balance. the problem is i am confused on the inflation layer on the solid-fluid interface. i need to finalize whether inflation is needed for solid or liquid layer?
Old   November 25, 2013, 02:12
For most simulations you need inflation on the fluid side but not on the solid side. But you should always check this for your case with a mesh sensitivity study.
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 21:05
[ANSYS Meshing] Inflation layer / Element quality Spookz ANSYS Meshing & Geometry 17 February 12, 2019 05:55
[ANSYS Meshing] Is an inflation layer necessary? ziggo ANSYS Meshing & Geometry 3 July 29, 2013 12:16
Problem with inserting a thermal contact resistance in domain interface. jerryx70c CFX 1 March 4, 2013 15:16
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
