1D Flow with Heat Addition
Hello dear engineers!
In first I must say that my English language is week! excuse me! I'm modeling a thin air flow in a simple path like a simple channel. Section of path is a rectangle. The inlet condition: Mach=0.2, P=1 atm, T=273 K and Heat is adding to the flow from top & bottom ( q=10^6 J/Kg) I have modeled the top & bottom in CFX-Pre as wall with heat transfer and I use mass rate for changing the "q: (J/Kg) " to "heat flux: (W/m^2)" But when I run CFX-Solver it exit with return code 225! 1- Is selecting the top & bottom as wall correct? 2- Is the changing I did true? 3- What is cause of error in your opinion ? thank you! |
Can you explain what the heat flow is? What does q=10^6 J/kg mean? Per kilogram of what?
I do not know of a system where the heat transfer to the fluid is proportional to the mass flow rate. My question is that this sounds like a non-physical system and then it only makes sense that modelling it is difficult.
If there is a constant heat input at the wall then use a heat flux boundary. If constant temperature then use constant temperature. There are also convective boundaries it that is suitable. |
Problem with 1D problem
Hi everyone!!!
I am trying to simulate a 1d heat transfer in a medium confined between two large walls (top and bottom wall). I created a 2d rectangle in icem cfd. For top and bottom lines I have given the boundary conditions as walls. But I am not clear what boundary condition I should use for left and right lines which are not supposed to be present. (I created them only for meshing).. Pls reply. |
Have a look at what the CFX tutorials do for the simulations where they need to put outer boundaries on which are not physically present.
