CFX Post Expressions number decimals
Old   November 29, 2013, 14:48
Default CFX Post Expressions number decimals
njiang is on a distinguished road
Hi, there,
I am creating an expression in CFX post using the trendline created in the Excel as following:
(-798936626.593750*z^6/1[m^6] + 4687121164.076870*z^5/1[m^5] - 11450097996.080200*z^4/1[m^4] + 14908481102.838800*z^3/1[m^3] - 10912008484.852500*z^2/1[m^2] + 4256979247.793130*z/1[m] - 691537634.412929)*1[K]
when I evaluate the expression using 0.91 for z, the CFX gives me wrong number 1536K, while Excel is 762K.
How do I change the decimal setup/precision in CFX?
Thanks.
Nan
njiang is offline   Reply With Quote
Old   November 30, 2013, 04:40
When you start the solver select double precision. But I vaguely recall that CEL is evaluated in single precision even with the rest of the numerics being double precision. I am not certain of this, but keep it is mind.
Old   November 30, 2013, 08:29
Hi, Glenn,
Thanks. I do have double precision turned on for solver.
Old   December 13, 2013, 04:39
Matthias Voß
mvoss is on a distinguished road
maybe you can use the "function"-function from cfx pre to overcome the rounding errors if the expression is supposed to be used in the simulation.
Be very careful about the resolution of the points being used in the function, because they will be interpolated piece-wise between two points.
You can also import data (like *.csv) for comparison in post - directly within the graph-tool.
mvoss is offline   Reply With Quote
Is it possible to obtain compressor map for axial compressor in CFX post ? Irondome CFX 1 June 16, 2013 06:24
ANSYS CFX simulation: Post CFX error MInXD CFX 3 May 19, 2013 19:24
Problem: Fluent axisym. in CFX Post areaAve j_h_86 ANSYS 0 March 20, 2013 08:33
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 12:18
(CFX POST) Rotational Speed ARJUN CFX 9 July 13, 2006 20:38
