December 2, 2013, 05:47 |
Exporting Geometry/Mesh files from CFX-Pre
Rep Power: 12 |
I have a CFX-Pre file and was wondering if it is possible to export geometry and mesh files so that changes to them can be made?
I am using ANSYS 14.0 Thanks, Stuart |
December 2, 2013, 05:57 |
Rep Power: 15 |
I think that the only file that can be exported from CFX is ccl. Geometry modification must be done in DM or external designer software
December 2, 2013, 06:03 |
Rep Power: 12 |
Thanks for your response.
Yes I know about exporting a .ccl file, however I am wanting to edit the geometry in DM within Workbench but don't see any way of exporting the current set up from CFX. Anyone got a solution to this? |
December 2, 2013, 06:55 |
Rep Power: 15 |
if it is linked (DM with CFX) via toolbox, then you can edit your geometry with DM and set up from CFX stays same
December 2, 2013, 07:00 |
Rep Power: 12 |
The problem is that I only have the CFX-Pre file. I would like to transfer this into Workbench so that I can alter the geometry etc. but I don't know of any way that this is possible. |
December 2, 2013, 07:02 |
Rep Power: 15 |
i don't think so because CFX works with mesh and because of different methods of meshing, some entities might be suppressed etc. At least I have never heard about this option
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
