ansys solver terminated with returne code -1
Old   February 13, 2014, 03:32
Default ansys solver terminated with returne code -1
Abhishek Raj
raj.091603.bme is on a distinguished road
Hello sir,
My work is related to fluid -structure interaction. for that i am using static-structural and Cfx for solid and fluid parts respectively.
Simulation goes on and meanwhile it shows error and stops. The Error is as follows:
| Job Information |
Host computer: MECH-PC (PID:273768)
Job finished: Thu Feb 13 11:20:47 2014
Total CPU time: 7.073E+01 seconds
or: ( 0: 0: 1: 10.728 )
( Days: Hours: Minutes: Seconds )
Total wall clock time: 7.000E+01 seconds
or: ( 0: 0: 1: 10.000 )
End of solution stage.
| An error has occurred in cfx5solve: |
| ANSYS Solver terminated with return code -1 |
| The results from this run of the ANSYS solver have been written to |
| C:\Users\mech\Documents\vasu_test_pending_tasks\dp 0_CFX_Solution_- |
| 1\Fluid Flow CFX_001.ansys |
| The results from this run of the ANSYS CFX Solver have been |
| written to |
| C:/Users/mech/Documents/vasu_test_pending_tasks/dp0_CFX_Solution_- |
| 1/Fluid Flow CFX_001.res |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
Please reply sir, what can be possible problem and how to remove the problm.
Thank you.
raj.091603.bme is offline   Reply With Quote
Old   February 13, 2014, 11:52
Matthias Voß
mvoss is on a distinguished road
Originally Posted by raj.091603.bme View Post
Hello sir,
| Job Information |
| written to |
| Warning! |
Thank you.
You need to provide the ANSYS.err file since ANSYS is crashing not CFX.
Check the displacement at the interface via Monitorpoints in CFX.
Check the mapping of the InterfaceInterpolation--> should succeed for ALL points on the Interface.
Get rid of every warning in the Ansys.err.
mvoss is offline   Reply With Quote
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 04:53
How to execute an utility inside the code of a modify solver? jmonsa13 OpenFOAM 2 July 13, 2013 14:01
CFX solver manager quits with error code 255 b.shuvayan CFX 16 November 7, 2012 01:48
setFields.C within solver code newOFuser OpenFOAM 3 April 9, 2012 11:15
modify the source code of simpleSRFFoam solver Pirlo OpenFOAM Programming & Development 0 October 19, 2009 09:49
