FSI error detected by routine PSHDIR
Hi all,
I´m doing a 2-way FSI with Ansys CFX and mechanical. Can you help me with this error? It appears while starting the first iteration with CFX. Details of error:- ---------------- Error detected by routine PSHDIR CDRNAM = /FLOW/GETVAR/BNCN_DIR/BCP1 /NOVARIABLES CRESLT = NONE Current Directory : /FLOW/SOLUTION/TSTEP0/CLOOP0/ZN1/BELG15/IP Thanks! |
The ANSYS CFX solver is trying to find the information for the non-overlap section of a domain interface. Check that the boundaries on either side of your domain interfaces have the correct Non-Overlap Boundary Conditions settings.
If the situation continues, you should contact ANSYS support |
