-   -   CCLDatabase Error - CFX-Solver Manager can not launch (http://www.cfd-online.com/Forums/cfx/127226-ccldatabase-error-cfx-solver-manager-can-not-launch.html)
ttu004 December 6, 2013 07:16
Hi guys
Could anyone tell me how to fix the problem when CFX-Solver Manager can not launch. A CCLDatabase Error message displayed as shown below:
Error sending CCL to database.
CCLAPI::loadCCLData:
CCL parser failed with message:
Perl Syntax errors detected:
syntax error at (eval8) line 3, near "D:/ANSYS workbench/0.75E6@11degree SST Mesh Sensitivity_files/dp0/CFX/CFX/Fluid Flow CFX_003.out';$Mo"
(Might be a runaway multi-line MM string starting on line 2)
Final $ should be \$ or $name at (eval 8) line 2, within string
Final $ should be \$ or $name at (eval 8) line 3, within string
Final $ should be \$ or $name at (eval 8) line 4, within string
This is the first time that I experience this, and I do not quite understand and even know what is the problem?
Thanks if anyone can give me any advice
Tom
ghorrocks December 7, 2013 05:11
While the error message is not particularly helpful, it does suggest there is a CCL error (or a perl error if you are using that) in the file it mentions. You need to look at the setup of that file.
chaitanyaarige October 26, 2015 08:20
Did you setup the case in higher version of the CFX (like 15 or 16) and tried to open in lower version (13 or 14) ??
