Please**need help on Tow phase flow ( water & steam water) analysis**
Dear friends
i want to model a cylindrical porous domain which has inlet at the bottom and outlet at top. porous has heat generation which make some water to become vapor. i modeled it as follow: 1- I defined one continuous fluid as water and one dispersed fluid as water steam ( bubble size 0.002 m) with IPWS F97 mat properties. 2- use of mixture model without free surface model 3- thermal energy 4- particle model 5- thermal phase change with saturation temperature 6- two resistance , zero resistance and ranze marshal models have been implemented. i try to run this problem for 1.014 bar domain pressure with 100 C saturation temperature which was successfuland two phase flow is performed. MY PROBLEM : BUT when i want to run it for higher pressure like 55 bar with 270 C saturation temperature, water don't become two phase and water temperature increases more than saturation temperature without phase change. what should i do please help me. :confused: |
hi
is there any body to help me:(
Have you covered the basics? http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
