-   CFX (
-   -   negative efficiency of centrifugal pump (
AdhavRohit December 24, 2013 09:09
2 Attachment(s)
please help someone.
my simulation is converging without showing any reverse flow. but the result is
negative efficiency
negative head generated
flow rate is ok.
ARohit December 26, 2013 00:22
Please help somebody..i am still sttuck.
please help somebody..
I tried every possibility..
changing mesh,
boundary condition
time step factor ... and what not...
thanks from heart.. !!
ghorrocks December 26, 2013 05:18
Are you sure you have the rotation and torque vectors defined correctly? And the flow set up correctly? Have you manually calculated the rotor torque and rotation to check it makes sense?
