January 9, 2014, 17:32 |
Vertical axis wind turbine - GGI problem
Hi Everyone,
I am trying to make a 2D simulation of vertical-axis wind turbine in CFX, and I have problem. My supervisor told me I have to make two domains- firts - a circle with cutted-out turbine shape; and second - a rectangle with cutted circle (for frits domain). Then I clicked "thin/surface" (My CFX does not maje 2D analise). I made mesh for both domains. And there is a problem in Solver. I tried to make rotating domain, but there's always an error. Could someone help me with that problem? I am beginner in Ansys. Errors: ERROR #001100279 has occurred in subroutine ErrAction. Message: Error number 1 found in subroutine CHECK_INIT. Interface Default Fluid Fluid Interface" connects a rotating and stationary domain, but has no frame change model. ERROR #001100279 has occurred in subroutine ErrAction. Message: 1 fatal error found in the problem setup. ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine CHECK_INIT I am pasting the results in attachment. Regards, Piotr Zwolinski |
January 12, 2014, 06:01 |
Rep Power: 143 |
Just like the error message says, you need to set a frame change model on your interface. Frozen rotor and transient rotor/stator are the most common choices, but others may be relevant depending on exactly what you are modelling.
Horizontal Axis Wind Turbine | CFD XUE | FLUENT | 22 | May 24, 2017 12:17 |
Airflow over Vertical Axis Wind TUrbine | sthoms78 | ANSYS | 8 | April 10, 2013 02:31 |
Wind turbine simulation problem | sanchovg2 | STAR-CCM+ | 12 | March 5, 2013 04:18 |
wind turbine simulation problem | dennis0131 | Main CFD Forum | 4 | November 22, 2010 04:26 |
Moment coefficient of vertical axis wind rotor | Agni | Main CFD Forum | 0 | August 28, 2008 06:07 |
