Help!!!Cfx modeling Volume Fraction Keeps Changing |
January 4, 2014, 09:24 |
Hi all,
For cfx simulation. I'm trying to set up a model which is a cup of fuel and air in a rotating frame. I chose my materials to be air@25c and c8h18l(all has constant density). And I set the volume fraction in the domain initialization to be air:0.6, c8h18l:0.4. I only used no slip wall(bottom and side) and 0atm total pressure(reference pressure 1 atm)opening(top) as boundary conditions so I expect to see the volume fraction to be constant all the time. But in the results I was super surprised to find the volume fraction changes with time(I used the transient state simulation). I went back to cfx-pre and added a monitor point volumeAve(Fuel.vf)@Tank and ran the solver again and got the same result. The fuel's volume function starts from around .25 instead of .4 and it drops steeply to .03 and then gradually rises to about .28 and stays around that value till the end. My question is why??????? is the volume fraction changing????????Why doesn't it start from the initial value I set it to be and stay there?????? Help I'm so confused right now |
January 12, 2014, 06:10 |
Rep Power: 143 |
It could be:
a) Your physics is wrong - you have selected physics which allows the volume fraction to decrease b) Your physics is correct but your numerics is inaccurate - then weird things can happen as the numerics is generating rubbish. Can you post an image of what you are modelling and your CCL? |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 00:10 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 10:46 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
