Compressible flow in CFX, valve simulation
Old   January 6, 2014, 04:56
Default Compressible flow in CFX, valve simulation
Ben Nicholls
bnicholls92 is on a distinguished road
I am currently performing some analysis in CFX regarding the flow through a high pressure air valve. This valve is designed to be used to prevent air leaks in the event that the airline on the valve outlet fails. I am performing this analysis with an inlet pressure of 207Bar and then I am varying the outlet pressure from 25 Bar up to 175Bar in steps of 25Bar. I am performing this analysis to make a design decision for the valve opening. So far my velocities have been sonic (>340.29m/s) at their peak and this does not feel right. However, I do not know how the density of the air is changing and would be interested in measuring this.
bnicholls92 is offline   Reply With Quote
Old   January 12, 2014, 07:20
Ummmm - 207 bar in air? This is definitely going to choke and go sonic. Why do you think otherwise?
Old   January 13, 2014, 05:05
Ben Nicholls
I have since found out that the system does not drop approximately 1Bar after each seismic gun fires. Instead, the system pressure at the manifold drops to approximately 75% of the line pressure after discussing this with a field service engineer. And this was shown to me using a simulated system.
Old   January 13, 2014, 05:18
I have no idea what you are talking about. Please post an image of what you are doing. You are going to have to explain what you are doing if you want us to help you.
cfx, compressible, flow, valve, valve simulation
Control Valve Flow Simulation Ashraf Sharara FLUENT 1 September 3, 2017 10:58
Compressible flow Simulation in CFDesign krishna_msrit Autodesk Simulation CFD 1 September 10, 2012 00:00
CFX - Solidworks Flow, Impeller comparison aerospace_guy_ CFX 8 March 20, 2012 23:06
Compressible flow simulation at mach .7 mbeals FLUENT 6 April 18, 2009 11:49
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
