Applying BEMT thrust distribution to actuator disk model |
January 13, 2014, 20:27 |
Hello
I've been trying to set up an actuator disk model in CFX for a ducted fan flow. I have a polynomial curve fit for a thrust distribution per unit span for a blade, however I'm not sure how to apply this to the actuator disk sub domain. What should be my first step? Thanks |
June 25, 2014, 22:41 |
Qiang Guo
Rep Power: 11 |
Hello
May be you can try to add a momentum source term in the sub domain. |
Applying a turbulence model to rhoCentralFoam | srinath | OpenFOAM Running, Solving & CFD | 13 | December 10, 2023 11:38 |
Applying turbulence model on laminar flow | mannobot | Main CFD Forum | 40 | November 30, 2016 02:46 |
Errorin subroutine appeared when applying cavitation model | pitisrisuk | CFX | 1 | July 2, 2012 03:36 |
applying results as b.c on some other model | manohar | FLUENT | 3 | October 10, 2005 07:03 |
applying post data as b.c on some other model | manohar | Siemens | 3 | October 10, 2005 06:38 |
