Logical Expression Interupt Control
I have defined a new dimensionless variable called Tstar. I am monitoring Tstar at various points in the domain whilst the simulation is running. I would like to set an interupt control which tells CFX to stop the simulation when Tstar > 0 at a particular point of my choice. Is there a way to do this using CEL and not user Fortran? If user Fortran is the only way then do you invisage it being simple to implement? Something along the lines of If Tstar > 0 @ Monitor Point 6 then stop End if Thanks |
Im not sure you can do that with CEL. Have you tried:
if(probe(Tstar)@MyMonitor > 0,1,0) ? (MyMontior being the name of the montitor) If that wont work you might be able to create a source point and go with if(probe(Tstar)@Source Point 1 > 0,1,0) ? |
Hi!
Thanks for the reply. I'll try it and report back. |
