January 9, 2014, 11:56 |
batch file problem Ansys CFX 15.0
Theodoros Papadopoulos
Rep Power: 15 |
I have just installed Ansys CFX 15.0. I tried to launch a batch file, but it does not work. I get the same erros each time, that the path can not be find. The weard is that the same batch file works fine with CFX 14.5.
does anyone have experience with batch file with Ansys CFX 15.0? thank you very much in advance for your help! |
January 12, 2014, 06:03 |
Rep Power: 143 |
You simply have the paths mixed up.
The easiest way to get the path correct is to start up the CFX launcher and choose tools/command line. This will start a command line with the paths set correctly. |
January 16, 2014, 12:28 |
Rep Power: 15 |
thank you very for the tip!
batch, cfx 15 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
