Home > Forums > CFX
Monitor points in multiphase flow
Old   January 17, 2014, 07:41
Default Monitor points in multiphase flow
stuart230588 is on a distinguished road
I am trying to create an expression for an additional variable monitor point.
The expression I have is: volumeInt(Radiation)@Fluid
This has been working fine for single phase fluid flow but I would now like to model multiphase and was wondering how to apply this to expression to a specific fluid.
Probably simple, I just can't think how to do it.
Thanks,
Stuart
stuart230588 is offline   Reply With Quote
Old   January 17, 2014, 08:03
JESS
Raijin Thunderkeg is on a distinguished road
Take a water-air system for example, if u want to monitor the air volume fraction mixing in the tank, u can use volumeAve(air.vf)@Tank.
Similarly, u can use volumeInt(Phase A.Radiation)@REGION in your case.
Raijin Thunderkeg is offline   Reply With Quote
Old   March 12, 2014, 10:14
Thanks for your reply, however I am still having problems with it.
When I enter the expression as you suggested, i.e. volumeInt(Air.Radiation)@Fluid I receive a different error message : The additional variable 'Air.Radiation' referenced in parameter 'Expression Value' in object '/FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POINT:Radiation does not exist in Domain 'Fluid'.
Thread Tools
Trackbacks are On
Multiphase Flow with NIST Real Gas Model Annka FLUENT 5 June 15, 2015 04:49
Capillary pressure in multiphase flow in porous media Lalit FLUENT 0 March 21, 2013 02:24
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 5 March 2, 2013 15:02
Review: Reversed flow CRT FLUENT 0 July 20, 2012 13:03
multiphase flow ,mass and volume fraction imbalance sope111 CFX 11 July 15, 2012 08:20
