Home > Forums > CFX
Computation of Y+ is not correct
Old   February 28, 2014, 04:45
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Why do you say DNS and RANS should match each other? They are very different approaches, so isn't some variation to be expected?
Old   February 28, 2014, 05:09
Lukas90 is on a distinguished road
Of course it is, but I compared the results with some other and the result of RANS matched in all cases the DNS-data and the wall function. So I think my results should do the same.
I my thinking the first calculated y+ value should be identical with the exported y+ value for the first node. And that's why i came to this modification...
Lukas90 is offline   Reply With Quote
Old   February 28, 2014, 05:29
Your results are already pretty close so you know you are not far wrong. If you expect that you can get your results closer to the DNS line then you need to do a careful validation of mesh size, convergence and time step size.
Old   February 28, 2014, 05:36
OK I will try this suggestions.
Thank you very much for your help Garrocks.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem with parallel computation (case inviscid onera M6) Combas SU2 11 January 30, 2014 02:20
Is my Dynamic mesh setup correct? cfd seeker FLUENT 14 January 26, 2013 15:01
computation of K, cp, h and s ?? megacrout OpenFOAM Programming & Development 6 October 11, 2011 06:02
inviscid 2d computation for M=0.3 flow past cylinder on fine mesh can not converge boubalos Main CFD Forum 3 March 20, 2011 05:26
